ArcGIS Server 10.3 caching error - "Output failure, error string = Error Moving Bundle"
6921
05-12-2015 04:49 PM
PhilipSlater
Greetings!
I am receiving and error when trying to create a MapService Cache in ArcGIS for Server 10.3 with all the patches.  The error is:
Output failure, error string - Error moving bundle
Failed to cache extent:
The Workspace is not connected
Failed to execute (ManageMapServerCacheTiles
Everytime I try the first level of cache (10, 577,790.554289) returns 100% then after 2 or 3 levels of other random percents it throws that error.  I want to say the workspace is connected because it caches some of the other levels.
How do I go about resolving this?  I am not even really sure where to start.  I verified my arcgis account permissions on the appropriate folders...
My setup is windows server 2012 running AGS 10.3 with IIS on one virtual machine and SQL Data (connected as dbo MSSQL 2012) and cache being stored on another Windows 2012 Virtual Server.
Any thoughts, or direction would be greatly appreciated.
Thanks.
JamesMonty1
Philip,
I have also received this message on and off recently. The last time this happened, I used the Manage Map Server Cache Status tool on the service, and afterward was able to successfully complete the cache build. Not sure if it will address the issue you are having, but it is an option.
James
PhilipSlater
James -
this work around only works some of the time.  My work around was to create the cache on a different server where the caching works.  Hopefully this was addressed in 10.3.1 and cache will get back to normal.
Sorry I dont have a better solution for everyone.
JohnFell
Just to add our own experience, we received this error when we were running out of hard drive disk space for newly generated tile images.
MichaelVolz
Esteemed Contributor
Try looking at this GeoNet post:
https://community.esri.com/thread/120116
There is a consumption patch mentioned for 10.3 that I believe is incorporated directly into 10.3.1 which my organization is currently using and not getting these error messages.
