ArcGIS Server 10.2.2 Initialize Errors
2494
09-08-2017 11:47 AM
MikeKaser
We are experiencing sporadic failures with map services. In the error logs in the ArcGIS Manager we see constant errors similar to below. The services will work fine for about a week but we are having to restart the ArcGIS Server service in the Windows service manager to get the services to behave again. ESRI support pointed towards performance but during a period where the services were not responding we looked at the ArcGIS Server Manager and there were no instances in use for any of our services, our processor, memory, pagefile, etc. all looked good. Restarted the AGS service and boom back in business. Any ideas?
Failed to initialize server object '<service name>': 0x80004005: Unspecified error
Internal Server Error. Error handling service request : 0x80004005 - Unspecified error
Failed to construct instance of service '<service name>'. Unspecified error
ScottFierro2
Single server or is it in a cluster?
Config-store on local drive or UNC?
MikeKaser
Single server. Config-store is on local drive.
MichaelVolz
Esteemed Contributor
What is the data source(s) for these mapservices (SDE database, file gdb, shapefile, etc.)?
MikeKaser
SDE.
