ArcGIS Pro 2.1
781
05-16-2018 09:17 AM
rajeshkumarg1
While executing the Stage Utility Network geoprocessing tool - unable to create the feature to feature class.
RROR 001904: SDE or DBMS admin user cannot create a utility network.
Failed to execute (CreateUtilityNetwork).
EXCEPTION
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\common\wrappers.py", line 90, in wrapper
    return func(*args, **kwargs)
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\untools\gptools\tools.py", line 193, in run
    service_territory_feature_class=new_svc)[0]
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\un.py", line 1779, in CreateUtilityNetwork
    raise e
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\un.py", line 1776, in CreateUtilityNetwork
    retval = convertArcObjectToPythonObject(gp.CreateUtilityNetwork_un(*gp_fixargs((in_feature_dataset, in_utility_network_name, service_territory_feature_class), True)))
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError:  ERROR 001904: SDE or DBMS admin user cannot create a utility network.
 Failed to execute (StageUtilityNetwork).
DanPatterson_Retired
You aren't working local on your machine (ie SDE) and do you need special permissions to use the utility network tool? (ie is the extension enabled? do you have data permissions?)
