ArcGIS Desktop 10.2.2 Database Connection to Oracle 12c Database
13233
12
10-22-2014 03:28 AM
KareemMorsy
Hello There
I am trying to connect from ArcGIS Desktop 10.2.2 to Oracle 12c database but the ArcCatlog just crashes every time. here are my environment settings
ArcGIS Machine :
ArcGIS Deskop 10.2.2
Oracle client 12c R1 32 bit
Instance :myserver:1522/orcl ( I have tried using all the usernames and passwords but still fails not only sde)
Oracle machine
Oracle Database 64bit 12c
Oracle client 12c R1 32bit
ArcSDE 10.2.2 ( only installation but the schema is not upgraded to 10.2.2, the whole exercise is to upgrade it from ArcCatlog)
Please not that i am able to connect through command prompt to the oracle database without any problems in the ArcGIS Machine.
I have even tried using Oracle client 11g.
Can you please take a look into that and I could not know if ArcGIS 10.2.2 is supporting 12c or not.
Thanks a lot
Tags (1)
Vara_PrasadM_S
Hi All,
We are facing the same issue with the same configuration given by Kareem. Could you please let me know how to fix this issue.
Thanks & Regards,
Vara Prasad.
TobiasFimpel1
I can connect to oracle 12c from arccatalog/arcmap 10.1 SP1 and 10.2.2 . The description of arcmap crashing is exactly what we faced after the patches were installed. If your DBA has installed these patches (and he probably has) he needs to grant SELECT_CATALOG_ROLE to the users. See the esri post linked to above. Please disregard if you already excluded this as a possible source of the issue.
