javaw.exe socket write error
4459
11-24-2014 08:29 AM
MarkusSchenardi
Any ideas what causes the ArcGIS Server to log the message below?
The corresponding process is javaw.exe which I understand is the main ArcGIS Server service itself.
The logmessage appears from time to time when sending queries to a FeatureService (coming in from webadaptor, connected with a secured connection on port 6443).
It probably only happens, if a GP-Service is running in the same time..
<Msg time="2014-11-24T15:51:01,745" type="DEBUG" code="9999" source="Rest" process="12" thread="20" methodName="" machine="servname.abcd" user="" elapsed="">ClientAbortException:  java.net.SocketException: Connection reset by peer: socket write error
  at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:413)
  at org.apache.tomcat.util.buf.ByteChunk.append(ByteChunk.java:371)
  at org.apache.catalina.connector.OutputBuffer.writeBytes(OutputBuffer.java:438)
  at org.apache.catalina.connector.OutputBuffer.write(OutputBuffer.java:426)
  at org.apache.catalina.connector.CoyoteOutputStream.write(CoyoteOutputStream.java:91)
  at org.apache.catalina.connector.CoyoteOutputStream.write(CoyoteOutputStream.java:84)
  at com.esri.rf.util.RUtil.jsonBytesResponse(RUtil.java:645)
  at com.esri.rf.RRequest.jsonBytesResponse(RRequest.java:832)
  at com.esri.client.app.templates.OperationTemplate.handleJsonResponse(OperationTemplate.java:244)
  at com.esri.client.app.templates.OperationTemplate.handleResponse(OperationTemplate.java:191)
  at com.esri.client.app.templates.OperationTemplate.execute(OperationTemplate.java:124)
  at com.esri.client.app.featureserver.FeatureLayerHandler.query(FeatureLayerHandler.java:270)
  at com.esri.client.app.featureserver.FeatureLayerHandler.service(FeatureLayerHandler.java:54)
  at com.esri.rf.RServlet.service(RServlet.java:110)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
  at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
  at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
  at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:603)
  at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
  at java.lang.Thread.run(Thread.java:744)
Caused by: java.net.SocketException: Connection reset by peer: socket write error
  at java.net.SocketOutputStream.socketWrite0(Native Method)
  at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:113)
  at java.net.SocketOutputStream.write(SocketOutputStream.java:159)
  at org.apache.coyote.http11.InternalOutputBuffer.realWriteBytes(InternalOutputBuffer.java:215)
  at org.apache.tomcat.util.buf.ByteChunk.flushBuffer(ByteChunk.java:480)
  at org.apache.tomcat.util.buf.ByteChunk.append(ByteChunk.java:366)
  at org.apache.coyote.http11.InternalOutputBuffer$OutputStreamOutputBuffer.doWrite(InternalOutputBuffer.java:240)
  at org.apache.coyote.http11.filters.ChunkedOutputFilter.doWrite(ChunkedOutputFilter.java:119)
  at org.apache.coyote.http11.AbstractOutputBuffer.doWrite(AbstractOutputBuffer.java:192)
  at org.apache.coyote.Response.doWrite(Response.java:517)
  at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:408)
  ... 29 more
Tags (1)
