ArcGIS Datastore
994
07-16-2024 01:17 AM
NevraÇorapsız
How do I access the data source of my layer that I published in ArcGIS Enterprise?
jcarlson
The purpose of Data Store is to make publishing, hosting, and managing your data something you can do entirely through the Portal's web interface or from Pro. So the short answer is: through your Portal's content directory. You're not meant to access the Data Store contents directly, if that's what you're asking.
Of course, there are many ways to publish a layer, so the data could be a file on the server, too. You'd need to elaborate on how the layer was published.
- Josh Carlson
Kendall County GIS
ArchitSrivastava
Hello @NevraÇorapsız,
Adding to what @jcarlson, the main question I would also like to understand, is "WHY". It would be good to know why that concern to access the data actually rises.
Perhaps, we can look into the workflow you are trying to accomplish by this and maybe improve on that.So there is no need for accessing the datastore.
Hope it helps!
