ArcGIS Data Store - Import Root or Intermediate Certificate
3461
09-26-2023 07:53 AM
Ranga_Tolapi
How to import Import Root or Intermediate certificate in to ArcGIS Data Store (version 10.9.1)? Can use updatesslcertificate.bat utility for this purpose?
Something similar to ArcGIS Server, refer to below screenshot.
AyanPalit
@Ranga_Tolapi You can use updatesslcertificate command utility
Reference: ArcGIS Data Store utility reference
Ayan Palit | Principal Consultant Esri
Ranga_Tolapi
@AyanPalit not found anything about Root or Intermediate certificate in the updatesslcertificate documentation.
MiguelParedes
Greetings @Ranga_Tolapi
As far as I know, the Data Store does not require the Root and/or Intermediate certs. Only what is referred to as the "server" certificate (.pfx or .p12)  I would assume because it is always accessed through port 2443 by the ArcGIS Server only, and never directly.  It would be great if someone would corroborate whether my assumption is correct.
I found this excellent article from our friends at Esri Australia that you may find of help: SSL Certificates in ArcGIS Enterprise components. It is very complete, but it does lack an explanation about why the DS does not require the Root and Intermediate SSL Certs.
Hope the above helps.
Miguel
AhmadIssa78
In ArcGIS Datastore machine(s) you need to run the command  updatesslcertificate, after you install the certificate on the ArcGIS Server machine(s). no need for any ( Root or Intermediate) crt or p12  certificates installtion on the datastore
Marc_Graham
We use the keystore explorer tool to import root and intermediate certificates.  You can find the datastore user and password using the listadminusers tool https://enterprise.arcgis.com/en/data-store/latest/install/windows/data-store-utility-reference.htm#...
this is definitely required if you are updating your arcgis servers with a domain CA certificate and you want to establish a full cert chain.
This is poorly documented and supported by esri. it should have a similar admin interface to the rest of the stack.
