ArcGIS Cloud Builder error. 404 Not Found Microsoft-Azure-Application-Gateway/v2
1598
10-05-2023 07:39 AM
DiegoLlamasOlivares
I am doing a deployment on a single machine using arcgis cloud builder 11.1, it finish but when i try to hit the url it send me error 404 Not Found Microsoft azure-application-Gateway/v2
i have tried to do this several times and always happed the same.
I already did a caconical name on godaddy https://gis.mapas.pr.gov to redirect to gismapas.eastus.cloudapp.azure.com
I do not know what else to check..
Any idea
Regards,
Diego
ChristopherPawlyszyn
Did you define the DNS alias appropriately in the SSL certificate section of the cloud builder application? There is the option to use a self-signed certificate, which would restrict access to the cloudapp.azure.com host, or an imported certificate, which allows traffic via the defined hostname.
If the wrong option was chosen there, the site will need to be undeployed and redeployed as the federation URLs are dependent upon this information and can't be easily updated for a configured system.
-- Chris Pawlyszyn
