Arcade Element in New Map Viewer Enterprise Version?
1665
03-21-2023 09:10 AM
RVx_GaslineGiS
I was following along on the ESRI blog posts about Arcade elements from early last year: https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/part-2-introducing-arcade-pop-up-con... and was trying to figure out how to configure a Fields List or Text added from "Add Content" to a popup...
And then I realized that all the examples were using "Arcade" from that Add Content button which wasn't available on our Enterprise Portal.
What version of Enterprise was that made available in? I'm currently on 10.9.1.
KenBuja
You can find out the Arcade version your Enterprise uses here. Enterprise server 10.9.1 uses Arcade 1.15 while Enterprise portal 10.9.1 uses 1.13
KenBuja
