arc map 10.1 on ec2 instance
753
09-27-2012 03:14 PM
NadeemQazi
i have created a new Ec2  instance on amazon  than using esri provided amis i have installed arcgis server 10.1  arc catlog arcmap on this instance. after that i authorize the server using the prvc file. i also have create a default site using cloud builder application. however when i remotely login on  my EC2 instance and tried to start the arc map i received following error:
proivde your licsence administrator following information
; error code =-96
licence server is down or not running
any suggestion what s wrong.
regard
nadeem
KimPeter
Did you also separately authorize Desktop?  You'll need to go into the ArcGIS Administrator and make sure you've authorized ArcGIS Desktop.
