Anyone using IIS/NLB in a multi-machine deployment?
6092
19
07-12-2019 12:14 PM
ThomasColson
Starting to seriously contemplate better failover. Any using https://docs.microsoft.com/en-us/previous-versions/windows/it-pro/windows-server-2012-R2-and-2012/hh... in this scenario?
ThomasColson
Can you expand on that? Are you saying that if using Multiple-machine deployment with ArcGIS Web Adaptor—ArcGIS Server (Windows) Installation Guide | Arc... , I can unregister a machine at a time, do my maintenance, but I'm not clear at what point do I (re-create? re-register) the site? It's the last machine step that's confusing. My goal is to have more uptime during maintenance, with performance as a side benefit but not requirements, I'm (hate to say happy but....) with my server performance, the bottleneck is SDE which I don't have the resources to solve (no desire to run a cluster or a mirrored DB farm). Another consideration is out of hundreds of services, only 2 are hosted, with perhaps a 3rd in the distant next 5 years. Everything else is a registered SDE DB. Another philosophical question is there any advantage, in this configuration, to adding a second web adapter and load balancing requests to the WA (which in turn is load balancing requests to the servers), or stick with a single WA and a simple multi-machine site?
ThomasColson
Jonathan Quinn‌ are there any updates on getting that documentation updated with what deployment scenarios can't be federated?
JonathanQuinn
Esri Notable Contributor
It hasn't made it in yet, but we're working on it. We plan to add a bullet under the Disadvantages section within the active/active and active/passive help, add it as a note to the Configure a hosting server for your portal section, and the add it to the advantages of multi machine sites here and here.
ThomasColson
Is there another source of this information? We're needing to make some configuration decisions rather soon.
JonathanQuinn
Not that I'm aware of. What other questions do you have when considering active/active or active/passive using the silo architecture vs multi-machine sites?
ThomasColson
Of all the possible deployment scenarios, which can't be federated with Ptl?
JonathanQuinn
The only deployment scenarios that can't be federated are the ones that use silo-ed, mirrored environments, (i.e. active/active and active/passive)
ThomasColson
JonathanQuinn
Yes, since the federation information is kept within the configuration store, the active/active or active/passive single machine deployment model won't work as each site has their own config-store. Making sure that each site creates the same service which is tied to the same item in Portal, (where the authentication is occurring), is impossible.
The multi-machine site approach, (either using the web adaptor or not), is the only way to set up a highly available/horizontally scaled ArcGIS Server site that is federated with Portal, since all machines are connecting to the same configuration store.
ThomasColson
Which is where I'm headed. I must admit, simply adding two more machines to a site with shared config has increased uptime substantially.
