Analyser claims a script is using a system dll when it isn't
3901
06-10-2015 01:39 AM
JonMorris2
Has anyone seen an error like this when trying to publish a GP result to server?
SEVERITYSTATUSCODEDESCRIPTIONNAMETYPEDATA FRAME
HighUnresolved00178Data: C:\Windows\system32\accessibilitycpl.dll, used by Script LFP Setup Basic cannot be copied to the serverLFPSetupBasicToolUnknown
HighUnresolved24032Data source used by Script LFP Setup Basic is not registered with the server and will be copied to the server: \LFPSetupBasicToolUnknown
JonMorris2
fyi, a similar error has been solved here.
Tl;dr - having the GP result in Arcmap TOC is confusing the analyser, so either use ArcCatalog or remove the result from the TOC.
