(Again): The base table definition string "CommunitiesRamallah" is invalid,
10629
10
01-20-2013 11:46 AM
JamalNUMAN
Legendary Contributor
The mxd is published successfully! but with error!: �??service started with errors�?�
[ATTACH=CONFIG]20902[/ATTACH]
What might be meant by �??The base table definition string "CommunitiesRamallah" is invalid?
[ATTACH=CONFIG]20903[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
BrandonNelson1
Just a tip:  I had this issue with ArcGIS Online, where don't have the ability to change folder and database permissions, etc.  I wasn't able to find the underlying cause, but in the end I managed to publish my service by running my map document through MXD Doctor beforehand.  This might even help with ArcGIS Server if the other suggestions aren't working for you.
