(Again): The base table definition string "CommunitiesRamallah" is invalid,
10602
10
01-20-2013 11:46 AM
JamalNUMAN
Legendary Contributor
The mxd is published successfully! but with error!: �??service started with errors�?�
[ATTACH=CONFIG]20902[/ATTACH]
What might be meant by �??The base table definition string "CommunitiesRamallah" is invalid?
[ATTACH=CONFIG]20903[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
JamalNUMAN
http://forums.arcgis.com/threads/66247-base-table-definition-string-is-invalid
Many thanks Richard. There is no answer there neither
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: rlwatson
Sorry Jamal.  I was thinking that perhaps the discussion on permissions might be relevant.
After sending the initial reply, I realized that you had probably seen this discussion anyway:(
AnthonyGiles
Honored Contributor
Jamal,
Is your 😧 Drive accessible by your server? When I add data into an mxd I always add in through a UNC path, I.e. //servername/data/.... This ensures that the server can access the data, have a look at this page:
http://webhelp.esri.com/arcgisserver/9.2/dotnet/manager/publishing/preparing_resources.htm
Regards
Anthony
by Anonymous User
Not applicable
Original User: [email protected]
Jamal,
Regards
Anthony
Thank you Anthony for the answer.
Sounds that the ArcGIS server is full of issues! Problems that never end
�??Is your 😧 Drive accessible by your server?�?� How could I check that my D drive is accessible to my Server?
What it is weird that I could publish my mxd with same conditions and enviroment! What is wrong with it now?
Best
Jamal
AnthonyGiles
Honored Contributor
Jamal,
What I mean is can your server see the 😧 of the machine your data is on. If you have the server on the same machine as your arcgis desktop this should not be a problem.
If the data is on another machine to your server then use a UNC path
Regards
Anthony
by Anonymous User
Not applicable
Jamal,
Regards
Anthony
Thank you for the prompt answer Anthony.
At the moment, the ArcGIS desktop and the ArcGIS Server are installed in the same machine (p1). Nevertheless, I got that message message.
[ATTACH=CONFIG]20941[/ATTACH]
Best
Jamal
AlagappanAL
I am facing the same issue. While publishing the map service in arcgis server 10.1 with a SDE layer, getting the error like base string invalid. Any clues to solve it.
by Anonymous User
Not applicable
Alagappen,
Does your arcgis server account have read access on your database?
Regards
Anthony
