Hi guys
My 10.6.1 was upgraded to 10.7.1 (Server and Image Server, Portal and Datastore - Relational and TileCache) last week on linux. Everything works well, but I can´t view Scene Layers created after the upgrade from CityEngine 2019.1, or ArcGIS Pro.
Here the logs on ArcGIS Server after try to upload one file.
| SEVERE | 12/02/2020 13:30:15 | Method failed.HRESULT = 0x80041202 : This is a FACILITY_ITF error that is specific to the interface that returned this error. See the documentation of the interface that returned this error for information about this HRESULT. | System/RasterProcessing.ImageServer |
| SEVERE | 12/02/2020 13:30:11 | Method failed.HRESULT = 0x80041202 : This is a FACILITY_ITF error that is specific to the interface that returned this error. See the documentation of the interface that returned this error for information about this HRESULT. | System/RasterProcessing.ImageServer |
| WARNING | 12/02/2020 13:30:11 | ClientCachingAllowed property not found. | System/RasterProcessing.ImageServer |
| WARNING | 12/02/2020 13:30:11 | IgnoreCache property not found. | System/RasterProcessing.ImageServer |
| WARNING | 12/02/2020 13:30:11 | CacheOnDemand property not found. | System/RasterProcessing.ImageServer |
| WARNING | 12/02/2020 13:30:11 | IsCached property not found. | System/RasterProcessing.ImageServer |
My steps
- Select my data on Cityengine --> Export models -> Scene Layer Package -->Export
- In Portal --> Add Item from my Computer - Upload with sucess --> Published Hosted Scene Layers
- Open a Scene View and Add the File
Here the same file on ArcGIS online
Hi Luiz - starting with ArcGIS Enterprise 10.7.1, you will need to install the Web Styles setup (available through MyEsri) to view anything beyond basic shapes. This is explained further in the documentation here. After installing, are you still having trouble viewing your scene layers?
Hi Jill
Yes it was installed. I can open old projects
Luiz, thanks for the details! With this information i\n mind, I recommend creating a case with your Esri distributor's technical support. You can do this by accessing the Support website here. Doing so would allow for an analyst to determine how to best assist you with the behavior you're encountering.
