Greetings,
I have a Portal for ArcGIS that I am trying to add a feature service to using the REST API. So far I've had success creating the service itself. When I try to add layers to it, I get a peculiar error message:
{ "error": { "code": 403, "subcode": 2, "message": "Access to admin resources are not allowed, Signed Request needed for 'AddToDefinition' with table", "details": [] } }
This message appears when I try to use the server admin interface to add the layer definition as well. Attached is the layer definition JSON. I should say that I have used the same definition to create a hosted feature service in ArcGIS Online with success. Does anyone have suggestions on how I can add feature layers to a service using the REST API on Portal? Thanks in advance.
