Adding to Arcade Expression Resets Custom Symbology from Images
1216
02-23-2022 10:00 AM
AdamBakiera
Good morning,
I am wondering if there is a way to get around something. I built a web map and corresponding web app with custom arcade symbology. In addition, the symbols are custom images (point feature layer). The current version looks and works great. However, I need to add a new point and image for that point. The problem I'm running into is that if I add a new line into my arcade expression, all of the custom images are reset and it would require me to set all of those custom images from scratch. This is not a major issue for this particular project at this point in time as we have about 20 data points but I can't imagine if someone has a similar set up and has 100+ data points. Is there a way for the custom symbology to not be completely reset when adding to an arcade expression? We are using Enterprise for ArcGIS version 10.8.1.
Thank you!
BrittanyBurson
This behavior also drives me nuts. No workaround that I know of.
