Add Extension - No response
2599
02-27-2014 03:46 AM
ShaningYu
Honored Contributor
ArcGIS Server:  10.1
Description:  Logged on as ArcGIS Server admin and then tried to add (SOE) extensions in ArcGIS Server Manager in the production server's.
Problem:  After clicking the 'Add Extension' button and then loading the soe file from C:\...\, Clicked the 'Add' button.  Then I got IE warning message (see the image) [ATTACH=CONFIG]31836[/ATTACH].  The message shows the blocked site is about:blank, but actually it is http://localhost that is in the list of my IE's Trusted site zones.
Question:  What security setting should be done to eliminate the blocking?
Thanks if you can help.
ShaningYu
Honored Contributor
1) In IE, go through menu, Tools > Internet Options.
2) Click Security tab and then highlight on the Trust Sites.
3) Click the Sites button to open the Trusted Sites wizard.
4) Add about:blank.
5) Click Close button and then OK button to complete.
After the setting, soe file can be added.
ShaningYu
Honored Contributor
4) Add about:blank.
MadhuHosuru
Hi Shaning Yu,
Many thanks for your input (above steps), it was really useful to resolve my issue while adding  MaritimeServer .soe extension through ArcGIS Server Manager.
