12.0 Web Adaptor Installation
1797
12-02-2025 09:40 AM
NICK_COG
Hello,
I am trying to deploy ArcGIS 12.0 in our development environment. We are moving from ArcGIS Enterprise 11.5. I was able to install Portal without any issue, but when I go to install the Web Adaptor for Portal I am getting stuck.
After running the downloaded ArcGIS Web Adaptor (IIS).exe file the Set Up Wizard does not launch. When I go to the downloaded files at the specified installation path and run Setup.exe nothing launches either. I tried downloading a fresh file from MyEsri and restarting the process, but that has not helped either.
I have checked and verified I have the correct .NET 8.0.7 and Microsoft Web Deploy 4.0.
I tried to manually run ConfigureIIS as outlined here: https://support.esri.com/en-us/knowledge-base/only-one-instance-can-be-installed-of-arcgis-web-adapt....
and received this error:
Any thoughts on what could be going on?
CodyPatterson
MVP Regular Contributor
Hey @NICK_COG
On a few articles I found that the Microsoft Visual C++ files may be missing or broken in some way. I would try to reinstall the package from Microsoft to see if that gets things working: https://learn.microsoft.com/en-us/cpp/windows/latest-supported-vc-redist?view=msvc-170
You can also try to do the elevated command prompt one-trick wonder that never seems to work for me but others have had success using this without quotes "sfc /scannow" which could repair the file!
Cody
CodyPatterson
Hey @NICK_COG
Cody
NICK_COG
That did it! Thanks a million.
CodyPatterson
Hey @NICK_COG
Great to hear! Hopefully the rest of the installations go smooth!
Cody
JoeRathvon
Thanks for this. It did the trick. now to try and get back the past few hours.
