0x80040154 - Could not create object 'ConfigurationFactory'
2822
04-02-2019 11:57 AM
skynumHu
When I created a new ArcGIS Server Manager, I got [x80040154 - Could not create object 'ConfigurationFactory'] error. Does anyone know why I got it? and How I can fix this error?
I also found that I do not have 'logs' folder in my root folder ‘arcgisserver’. Is it a reason why I got this error? if yes, how can I fix it?
Thank you for your help
WoutDamiaans1
I have the same problem, were you able to find the cause and a solution?
Kind regards
wwwdavid
I got a similar problem with the same error code. Some searching suggest that might be a call to 32bit architecture in a 64bit environment?
PGF50
Hi David,
Did you manage to sort out this issue?
