Vector Tile Layer - Popups in Web Map?
515
11-06-2025 05:36 AM
Labels (2)
JonM32
Hi everyone,
Is it possible to enable popups for a vector tile layer in a web map? I'm using Enterprise 11.3
I've seen a few threads on this topic before (like this one), but I wanted to see if there has been any update on it. So far, it seems like this functionality is not possible in web maps from what I've read. I was able to enable popups in ArcGIS Pro for the vector tile layer I created, but still no luck in the web map.
Any insight is appreciated!
Thank you,
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
