Unable to print from the Map Viewer if the web map contains the living atlas layer
1066
12-27-2019 12:12 PM
KevinCopeland
Unable to print from the Map Viewer (portal) if the web map contains the living atlas layer.
an error occurred while printing the map
what are the requirements for being able to print using the living atlas layers?
Tags (4)
BlytheSpendlove
Hi Kevin, I had this same problem. I am in an Enterprise Portal environment, and had to share the living atlas layer with "the public" for the print service to successfully print the layers. I don't know how it works however outside of an Enterprise Portal environment.
