Still getting credential request after setting up SSO with Automatic Log in using Active Directory and IWA?
1105
09-20-2023 10:01 AM
Amarz
Hello, I am trying to configure Automatic Login for my organization to access Organization shared gis data and web services, but I am still getting the following prompt when they attempt to access the provided URL..
So far I have configured the following:
  1. Portal set to allow access to portal through HTTPS only
  2. Do not allow anonymous access to portal
  3. Portal Admin connected to Active Directory
  4. IIS on Portal's webadaptor set to:
    1. Anonymous Authentication = Disabled
    2. Windows Authentication = Enabled
  5. Internet Options are set to Automatic Login only in Intranet zone
I was following Use Integrated Windows Authentication With Your Portal
Any advice on what to check next?
Scott_Tansley
MVP Regular Contributor
Can I ask if you're seeing this from the internet or the intranet?
Scott Tansley
https://www.linkedin.com/in/scotttansley/
Amarz
Apologies for the delay, this was on the intranet side.
