Simple elevation profile widget
1919
01-13-2023 07:09 AM
JenniferGrove
Hello, Community,
Is there a simple elevation profile widget available in the Enterprise portal?  I would like to use it in a web map.  However, I do not see one in the ArcGIS Web AppBuilder.  When I try to create web app using configurable apps, I do see that under explore/summarize data, there is an elevation profile.  However, I am unable to get it to work.
Thanks for any help in advance!
--Jennifer
AndrewFarrar
If you use the WAB Developer version, you can import this custom widget that Robert Scheitlin created:
https://community.esri.com/t5/web-appbuilder-custom-widgets-documents/elevation-profile-widget-versi...
AndrewFarrar
JenniferGrove
Thank you for sharing this!  I saw this but am not sure about using the developer version.
