Shadow behind polygon
7548
03-04-2014 06:43 PM
BradleySmith2
Does anyone know how to produce a shadow behind a polygon like the attached example?[ATTACH=CONFIG]31940[/ATTACH]
Paulvan-Cuylenburg
Paulvan-Cuylenburg
Cartographic Representations is the easiest way...
http://blogs.esri.com/esri/arcgis/2011/11/04/figure-ground-drop-shadow/
BradleySmith2
When I tried this method, I got an error message saying, "The workspace for this feature class doesn't support representations." I'm not sure what I am supposed to do to address this problem.
NidhinKarthikeyan
Honored Contributor
Make sure you have ArcGIS for Desktop Standard or ArcGIS for Desktop Advanced license. Also the input must be a Geodatabase Feature Class.
