Proper case label expression
1162
08-13-2012 01:28 PM
TanyaOwens
I am trying to convert all caps to proper case with more than one word in the field. For example the text in the field is "IRONWOOD RIDGE DR" and I want it to display as "Ironwood Ridge Dr".  The example expression at
http://resources.arcgis.com/en/help/main/10.1/index.html#//00s800000027000000 capitalizes the first word and lowercase for all other words so I end up with "Ironwood ridge dr". Any help would be appreciated.
Thanks!
TanyaOwens
Thanks for the help but in the meantime I found the code in the help dialog button that was perfect (who would think to look there - it has been a long Monday) :):
  Function FindLabel([Name])     var = [Name]    splitStr = Split(var, chr(32))    for i = 0 to UBound(splitStr)       tmpStr = Trim(splitStr(i))        if len(tmpStr) > 0 then tmpStr = UCase(Left(tmpStr,1)) & LCase(Right(tmpStr, Len(tmpStr) -1))    splitStr(i) = tmpStr    next    ProperCase = join(splitStr, " ")    FindLabel = ProperCase    End Function
AnthonyGiles
Honored Contributor
Tanya,
Have a look at this post:
http://forums.esri.com/Thread.asp?c=93&f=982&t=190787
Regards
Anthony
TanyaOwens
