Problems Creating Projection File
5246
9
10-16-2012 08:12 AM
ScottAtherton1
I was given some CAD Data and told it was in a 10TM projection, included in the meta data was the following information:
GEOGRAPHIC LOCATION:         Latitude: 49:0:0
                                         Longitude: 110:0:0
PROJECTION:            10 DEGREE TRANSVERSE MERCATOR
PROJECTION ID:         0202
CENTRAL MERIDIAN:      115
COMBINED SCALE FACTOR: 0
IGDS GLOBAL ORIGIN:    X = 500000    Y = -5000000
DESIGN SCALE:          1000000
DATUM:                 NAD83
COMMENTS:              1:1,000,000 POSITION FILE
This is my attempt at the projection file:
PROJCS["10TM",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",-5000000.0],PARAMETER["Central_Meridian",115.0],PARAMETER["Scale_Factor",0.0],PARAMETER["Latitude_Of_Origin",49.0],UNIT["Meter",1.0]]
If someone could explain where I am going wrong that would be fantastic, keep in mind I am a relatively novice user,
Thanks in advance
MelitaKennedy
Esri Notable Contributor
I see a few possibilities. Canadian data, right? The information doesn't match any of our existing 10TM definitions, unfortunately. First, change the central meridian to -115. (115W).
Also I would try changing the latitude of origin to zero. I think geographic location just identifies the area of the data, and may not have anything to do with the projection parameters. With the latitude of origin set to the equator, Y values will be around 5-6 million. However, with a -5000000 m false northing, that will reduce the size of the Y values.
Lastly, change the scale factor to 1.0. Scale factor is applied as a multiplier to the numbers coming out of the algorithm, before the false easting and false northing values are added.
Melita
ScottAtherton1
Yes it is data from Canada in fact this is what altalis has provided (the official data distributer of the Alberta Government). It looks like I am still missing something here, this is what the projection file looks like now:
PROJCS["10TM",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",5000000.0],PARAMETER["Central_Meridian",-115.0],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
Thank you for your help on this
MelitaKennedy
Try changing the false northing to -5000000.
Melita
ScottAtherton1
Humm ok I tried that, and now when I bring the layer into Arcmap I am getting the Inconsistent extent Error message
PROJCS["10TM",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",-5000000.0],PARAMETER["Central_Meridian",-115.0],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
MelitaKennedy
Can you post the data's current extents (using this coordinate system), plus a general idea of where it should be located?
Melita
ScottAtherton1
I can do even better than that, the data is from the following link
http://www.altalis.com/prod_base_small.html
it is the 1:1 million data and it covers all of alberta
MelitaKennedy
Okay, I downloaded the DWG. Ignore everything I said and what the metadata says. Just assign the NAD 1983 10TM AEP Resource prj to the data. A quick way to check it is to add the AltaLIS data to ArcMap. You should get a 'missing coordinate system' message; ignore it. Add some reference data. Set the data frame's coordinate system to the AEP Resource coordinate system. The reference data, as long as it has a coordinate system, will get projected on-the-fly and should line up.
Melita
ScottAtherton1
Alright now we are in business thank you very much, I don�??t fully understand why my approach didn�??t work it seems like it should have, was the meta data wrong?
MelitaKennedy
I don't know. I believe the metadata's correct for the CAD software, so someone working with it in that software would need to know that information. Because the data was georeferenced to a 'known' coordinate system, it just works in the GIS software.
Melita
