problem using laharz
1913
11-06-2023 05:24 AM
rifkwak
Hi! My running data on Hazard Zone Proximal is too fast (less than 1 second) so the result is not appear. Can someone help me to solve this? By the way i am using arcgis 10.2.2 and already used various version of arcgis but still couldn't solve this problem. Thank you!
Tags (3)
ChrisUnderwood
Hello @rifkwak , unfortunately ArcGIS 10.2.2 was retired a while ago. I suggest you upgrade to a current version and try again there.
https://support.esri.com/en-us/products/arcgis-enterprise/life-cycle
rifkwak
is the laharz toolbox also compatible with the latest version of arcgis?
ChrisUnderwood
@rifkwak  , the USGS have an old (2014) article that states Laharz_py is "for use with ArcGIS, version 10 or later". You should probably check with them for more recent information.
https://pubs.usgs.gov/of/2014/1073/pdf/ofr2014-1073.pdf
But this previous Community posting does contain a Solution that might be more helpful to you.
https://community.esri.com/t5/python-questions/laharz/m-p/288480#M22348
