Portal login hangs up on accountswitcher-callback.html
2274
06-19-2024 01:20 PM
FredSpataro
Hi All,
Got a portal issue that came up recently, not sure what we tweaked that caused the issue but ...
  1. login to the portal using a built-in account
  2. web page hangs up on the "vertical bars loading image" on the url: {host}/portal/home/accountswitcher-callback.html?{yada}
  3. edit url to the main portal home and portal loads with the account logged in
So it seems like login is successful but something in the javascript running the accountswitcher-callback.html is failing to complete.  No error in the dev tools console.  Network requests all look good.
Any thoughts on what might be hanging it up?
SushilPradhan2
Have you found solution to this issue? I am also experiencing same after upgrading to ArcGIS Enterprise 11.3.
-Sushil
FredSpataro
Hi @SushilPradhan2
So far not yet, still just clicking refresh when it happens... If you track it down, please post.
Thanks!
MortenMa93
@SushilPradhan2 @FredSpataro Did you find a solution on this problem?
FredSpataro
Hi, sorry haven't found a solution. Let me know if you're able to dig on up.
