Portal home page does not load completely on Chrome Version 127.0.6533.73
12872
8
07-29-2024 11:38 AM
Jamie_Leitch_CNF
I just noticed starting today that when I login to Portal on Chrome browser Version 127.0.6533.73, the home page does not load fully.  The login seems successful, but the menu at the top does not show up. On Chrome version 127.0.6533.72 this did not happen.  I'm seeing this in the console:
The link: https://chromestatus.com/feature/5083947249172480 seems to indicate some code change on July 30, 2024.
Anyone else have this issue, and if so, is there a fix coming?
thanks
ReeseFacendini
Esri Alum
Please install the Portal for ArcGIS Application Display Patch either using the Check for Enterprise Updates tool, or by going to https://support.esri.com/en-us/patches-updates/2024/portal-for-arcgis-application-display-patch and downloading the correct version for your deployment.
BlakeTerhune
What version of Enterprise are you on?
Jamie_Leitch_CNF
ReeseFacendini
Esri Alum
JenniferMcFarland
Please see this knowledge base article.  It has links to a patch based on what version of enterprise you are on.   https://support.esri.com/en-us/knowledge-base/impact-of-google-chrome-and-microsoft-edge-127-updates...
Hope this helps
Jenn
Craig_Lunde
@Jamie_Leitch_CNF Did installing the patch work for you? We are still getting the error after we installed the new Portal for ArcGIS Application Display Patch.
Jamie_Leitch_CNF
@Craig_Lunde yes it did work, but only after clearing the browser cache.
bthavara
Hi Craig,
Did this issue resolve for you ? We are still getting the error after we installed the new Portal for ArcGIS Application Display Patch and clearing the bowser cache does not seem to help either
Pei-SanTsai
I did apply the patch for 10.9.1.   I'm having issue with the Chrome browser even after cleared out the web browser & relaunched the browser.  I don't have issue with Edge.  Edge is the default web browser at work, but we do have people using Chrome.
