Portal for ArcGIS Depolyment Scenario
18147
22
02-18-2016 06:42 AM
ApurvDanke
I want to setup portal for ArcGIS in my development environment. Currently I have ArcGIS Server 10.3.1 and Web Adaptor installed on same machine. I have configured the ArcGIS Server in Web Adaptor. Can I install Portal for ArcGIS on the same machine and configure it through Web Adaptor, so that both ArcGIS Server and Portal for ArcGIS would work on the same machine? Is there any restriction or disadvantage in doing that?
Regards,
Apurv
SharonMeier
Hi Derek,
I'm working with the final release version of 10.4 now and am getting the same invalid redirect_uri error.  Just posted a new question in the GeoEvent forum.    I only get this error when I have my server and Portal federated.
By the way, I attended a couple of your sessions at Dev Summit and found them very helpful.
DerekLaw
Esri Esteemed Contributor
Hi Sharon,
Belated thanks for the kind feedback on my Dev Summit tech sessions.
Best,
ApurvDanke
What I finally did was to first install an SSL domain certificate with help from the IT guys, on the same server. Then I did the binding in IIS for https with this certificate. Later I installed the web adaptor but chose port 443 for https and gave a different name for the web adaptor instance.
Thanks for all your inputs.
Regards,
Apurv
