Polar Stereographic Projection
1664
08-27-2012 01:27 PM
GabrielMcMahan
I was asked to create a map in a custom projection for meteorological data and I am having some trouble figuring out how to specify the projection in ArcGIS.
This was the description of the projection.
"The map projection we use is a local polar stereographic one.
map_proj = 'polar',
ref_lat   =  59.20,                <------------------- projection point
ref_lon   = -145.3,              <------------------- projection point
truelat1  =  60.1,
truelat2  =  90.0,
stand_lon = -149.3"
I've tried a few things, but I can't seem to get the map to match some hard copies he already has.  Does anyone have any insight into using this information in ArcGIS?
Gabe
MelitaKennedy
Esri Notable Contributor
Hi Gabe,
I'm wondering if this data is actually using a rotated world. Perhaps 59.2, -145.3 is the equivalent of the north pole, with -149.3 showing where the central meridian runs (which will be either north or south from the center point) and 60.1 is a standard parallel on the rotated world.
Hmm, according to this tutorial:
stand_lon = longitude/meridian parallel to the y-axis.
truelat1,2 = standard parallels (2 is only used for lambert conformal conic)
ref_lat, ref_lon = set the center of the displayed data
Have you tried using Stereographic_North_Pole with:
central meridian = -149.3
standard parallel 1 = 60.1
Do you have the sphere's radius value? Because that will throw off the calculations if you're using a standard GCS like WGS84.
Melita
GabrielMcMahan
thanks for the input Melita.  I did try
and it is pretty close to the example map, however there is a slight counter clockwise rotation in my system compared to the example map.  I did use WGS84, so there is a good chance that the GCS is my problem.
