Plotting  using azimuth bearings and distance
11506
08-30-2012 02:58 AM
dfcitadmin
I have the coordinates of a fixed point in Lat / Long format.
I have a True North Azimuth bearing from that point,
and I have a distance along that bearing in miles.
My problem is: How do I plot the point which is at the end of the bearing?
I am using ArcGIS 10 with Ordnance Survey Great Britain mapping.
Following on from this I then want to plot that position in 3D using the height at that location in feet , for that I will use ArcGlobe.
My ultimate goal is to be able to plot several 3D positions using bearings and distances from a common source to produce a 3D track.
Any pointers to where to go would be most helpful.  Thanks.
Derek
AnthonyGiles
Honored Contributor
Derek,
Have a look at the Bearing Distance To Line tool that was added in 10:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//0017000000ts000000
Regards
Anthony
AnthonyGiles
Honored Contributor
Derek,
Regards
Anthony
dfcitadmin
Many thank, for both suggestions.  I am using the Bearing to line tool.
AnthonyGiles
Honored Contributor
Derek,
Please don't forget to mark the post that best answers your question as follows:
[ATTACH=CONFIG]17728[/ATTACH]
regards
Anthony
