Moving map document annotation - grid fineness
781
01-25-2013 09:38 AM
PhilipMorrison
Is it possible to change the fineness of the grid ArcMap uses to position map document annotation using the arrow keys?  For example, I create a small circle graphic and then place a number in the circle.  In ArcMap 9.3, I was able to tweak the placement of the number using the arrow keys to get it as close to center as possible.  However, with 10.1, each use of the arrow key is too coarse.  One hit of the arrow key will throw the number clear out of the circle.
Is there some way to make the movements associated with the arrow keys a little finer?
Phil
