Limit to the size of an item to publish to portal (size exceeds the configured maximum)
2196
03-10-2021 11:26 PM
AshComer
I've installed a vanilla instance of ArcGIS enterprise 10.8.1 under a H/A multi-machine architecture.
I'm attempting to 'load' a .slpk file that is 34Gb in size but it is reporting the below error:
Maximum file size exceeded. Failed to upload item. the request was rejected because its size (23981704193) exceeds the configured maximum (104857600)
Is there a simple configuration setting that can be  increased?
Thanks.
Ash
JayantaPoddar
What steps have you followed to upload the SLPK file to Portal?
Have you tried uploading it from ArcGIS Pro Geoprocessing tool?
Share Package (Data Management)
Think Location
