Label expression formula question
2028
7
10-26-2012 07:56 AM
QuinnMcCarthy
using vb script is there a way to extract the number 1 from a field in the attribute table that has 'County Road 1'? I hope that is not confusing.
Thanks much.
Quinn
Koochiching County  MN
QuinnMcCarthy
To make this more clear I need to extract everything to the right of the rihjt most space. Becasue some roads are 1E or 1S.
Thanks
Quinn
AnthonyGiles
Honored Contributor
Quinn,
Do you just want to remove the number 1 when the label is shown, if so use the replace function:
Function FindLabel ( [Road_Name] )
If Not IsNull([Road_Name]) Then
NewStr = Replace([Road_Name]," 1E","")
NewStr = Replace(NewStr," 1S","")
  FindLabel = NewStr
End If
End Function
Regards
Anthony
RichardFairhurst
Thanks
Quinn
If there are always just 1 or 2 characters at the end of the value with a leading white space, in VB Script you can use the Right function with the LTrim function to get the last non-white space character or characters:
LTrim(Rigth(myFieldValue, 2))
To get all of the characters to the left of the last 1 or 2 characters excluding a trailing white space use the Left Function, the Len function and the RTrim function as follows:
RTrim(Left(myFieldValue, Len(myFieldValue) - 2))
Both of these are simple label expressions.
QuinnMcCarthy
Thanks Richard and Anthony. I will give them a try.
I think Richards answer might be what I am looking for. We will see.
Quinn
AnthonyGiles
Honored Contributor
Quinn,
The only problem I see that could occur with Richards suggestion is that all roads will have to end with 1E or 1S otherwise you will cut the last two characters off the name,
Regards
Anthony
KenBuja
MVP Esteemed Contributor
You can use the Split function to put the words into an array and just retrieve the last item in the array.
     arrString = Split([Road_Name])
     FindLabel = arrString(UBound(arrString))
  End If
End Function
AnthonyGiles
Honored Contributor
Quinn,
Sorry, I think I missed understood what you are trying to achieve, I read it that you have road names which end in 1E or 1S and you wanted to remove them on your labels, i.e:
'Pinewood Road 1E' would be just 'Pinewood Road'
If you want everything right of your last space in the attribute value use:
if InStrRev(txt," ") > 0 Then
right([Road_Name],len([Road_Name]) - InStrRev([Road_Name]," "))
End If
everything left of your last space use:
left([Road_Name],InStrRev([Road_Name]," "))
End If
Regards
Anthony
