IWA Login for Portal Prompting for Credentials
10009
13
08-03-2018 12:00 PM
Andrew-Bowne
Hi All!
I have IWA configured for our on-premise portal and we are having a problem where users are being prompted to enter their Windows credentials before accessing portal.  From the documentation that I have read, users should pass right through and not have to log in at all as long as they have a user account (which they do).  From the Documentation:
When you use IWA, logins are managed through Microsoft Windows Active Directory. Users do not sign in and out of the portal website; instead, when they open the website, they are signed in using the same accounts they used to log in to Windows.
Does anyone else experience this?  Is there a workaround or an IIS setting that I'm missing?
I can add the URL as a Trusted Site but I don't see this as a viable solution.
Thanks!
NickHarvey
Yep that did the trick (now works in Private Browsing, etc) Thanks Again!
NathanHeickLACSD
I wanted to add to this topic.  I was having similar behavior.
What I found was that I was using the etc/hosts file while migrating to a new server to map our production server alias to the local server.  Initially, I entered the following:
#.#.#.#  alias.domain.com
It worked for a lot of things like setting up the web adaptor.  It didn't work once I got to setting up IWA.  While troubleshooting, I tried using the machine name instead of the alias and IWA worked.  So, I then tried modifying the etc/hosts file as follows:
#.#.#.#  machinename.domain.com  alias.domain.com
I'm not well-trained in networking so I don't know why leaving the machine name out of the entry caused an issue.  I do know it fixed my problem.
Marshal
I am working on doing the same and this really helped me out!  Thanks a bunch!
NitinChauhan
