Issue with Layer Widget Display in Experience Builder 11.5 on Firefox 145.0
3829
16
11-11-2025 02:16 PM
BrantGossett
I’m encountering an issue with ArcGIS Experience Builder: after upgrading to Mozilla Firefox version 145.0, the Layer (or Map Layers) widget fails to display. Has anyone else seen this behavior?
MICHAELSIELI
our 11.3 instant apps apps won't load with firefox 145 either (and they will load with 144).
MICHAELSIELI
does it help to uninstall and install a previous version on the server itself?
MistyDowning
yes just discovered this with an experience builder app today. 11.5. exactly as you described, new firefox update and now the layer list widget opens but fails to display any actual layers.
MJhendo
Happens to us on both AGOL and 11.5, and also affects the map viewer (only the map itself loads alongside the usual site header, but none of the usual side panels).
Bryan_Neely
also seeing UI not visible on left side of map viewer w/ 145.0.
esri support saw issue after updating to 145.0
Zane
Also seeing the same behavior after updating to Firefox version 145.0.
LMFGeospatial
This isn't just happening in Experience Builder nor is it limited to the layer list widget. I have a custom JS application built with Esri JS 4.33 and I am experiencing the same thing with my arcgis-layer-list map component.
LMFGeospatial
I will add that in hope of solving the issue, I have started to migrate my applications to the new Esri JS SDK 4.34. And the issue persists there - so upgrading to 4.34 does not solve the problem. And besides components like arcgis-layer-list and arcgis-legend being wonky, some of my responsive behavior is not cooperating. I use the Bootstrap front-end framework for my applications. I have JavaScript in place that moves specific components around depending on either initial page size (like a mobile device vs a desktop) or even page resizing actively carried out in a desktop browser. This code has worked for years. And in both 4.33 and 4.34, it still works in Edge, Chrome, and Safari. But it does not work in Firefox v145 and above. I downloaded Firefox Nightly (v147) and the layer list and legend components seem to work again - but the responsiveness still does not. And the application on a mobile device does not load properly at all.
Jared_Yost
I have also experienced these issues.  Only on Firefox.  Also tested on Enterprise with all patching done last night.  Has this received Bug status yet?
