Is it possible to share the content between two Portal for ArcGIS 10.3.1 without configuring other high availability parameters ?
2597
01-17-2016 10:54 PM
KareemMorsy
I have Installed two separate Portal for ArcGIS . I want to share the content between both in a new shared location on a file server. What I am trying to achieve is  having one Portal in Arabic and another Portal in English. but when I follow the normal high availability configurations. If I set one Portal for ArcGIS to Arabic the secondary Portal also get set to Arabic. So I need only to share the content with out providing the rest of high availability parameters ( Public Url , Private Url and Second Portal Machine)
Regards
Kareem
Tags (1)
BillMajor
Unfortunately, I don't think this is possible at this time.  You could use tools (like Python or AGO Assistant) that could copy items between 2 different Portals and probably maintain the different language settings.
