I would like to invalidate the session and/or remove token of my user by using portal rest.
I see that i can navigate till this address https://<community-url>/users/<userName>/invalidateSessions but i can't see the adress call when i put the button to invalidate session.
I also try with https://<oauth2-url>/revokeToken but i have http 400 error : Invalid URL.
Could you held me to disconnect my users ?
Guillaume ARNAUD
Hi Guillaume,
What release of Portal for ArcGIS are you using? The /sharing/rest/oauth2/revokeToken operation was added in 10.7.1 so anything older would return the 'Invalid URL' error message you are seeing. Prior to 10.7.1, the oauth token could only be revoked by calling oauth2/signout.
Jeff
Hi Guillaume,
Both of those methods should work fine to invalidate tokens. The urls just need to be adjusted to match your Portal url.
https://yourportal.domain.com/web_adaptor/sharing/rest/oauth2/revokeToken
and
https://yourportal.domain.com/web_adaptor/sharing/rest/community/users/<username>/invalidateSessions
Keep in mind that these only invalidate OAuth tokens. They cannot be used to invalidate tokens created through the generateToken operation.
Jeff
I need to revoke only one token of a specific app. I try to use https://yourportal.domain.com/web_adaptor/sharing/rest/oauth2/revokeToken (Revoke Token—ArcGIS REST API | ArcGIS for Developers ) but it doesn't match.
I call url in post in JAVA :
String data = "";
int i = 0;
for ( Entry<String, String> entry : this.url_param.entrySet() ) {
if ( i != 0 ) {
data += "&";
data += URLEncoder.encode( entry.getKey(), "UTF-8" ) + "=" + URLEncoder.encode( entry.getValue(), "UTF-8" );
i += 1;
// création de la connection
URL url = new URL( this.adress );
HttpURLConnection conn = (HttpURLConnection) url.openConnection();
conn.setDoOutput( true );
conn.setInstanceFollowRedirects( false );
conn.setRequestMethod( "POST" );
conn.setUseCaches( false );
// envoi de la requête
writer = new OutputStreamWriter( conn.getOutputStream(), "UTF-8" );
writer.write( data );
writer.flush();
// lecture de la réponse
reader = new BufferedReader( new InputStreamReader( conn.getInputStream(), "UTF-8" ) );
String ligne;
this.page = "";
while ( ( ligne = reader.readLine() ) != null ) {
this.page += ligne;
The URL seems to be correct :
https://lacarto.ledepartement82.fr/portail/sharing/rest/oauth2/revokeToken
Parameters to :
{f=json, auth_token=<token>, client_id=<appId>}
but :
{error={code=400, messageCode=GWM_0002, details=[], message=Invalid URL}}
Could you help me ?
Guillaume
Hi Guillaume,
Jeff
Ok, i don't read this informations on help. We are in 10.6.1 so it's normal.
Need to update.
