Install-PreReqs.ps1 - Missing closing ')' in expression.
1129
10-04-2019 06:16 AM
CliveSwan
Occasional Contributor II
greetings,
I have just started using the PowerShell Automated Base Deployment, and I am updating the configuration files.
I have got an odd error when updating the Install-PreReqs.ps file.
The error is:
Install-Prereqs.ps1 -ServerMachines ["serverName"-ModuleSourcePath ["Path\"]
Param(
    [System.Array]  << Error at the bracket after .Array
    $ServerMachines,
    [System.String]
    $ModuleSourcePath
) << Error at the closing ")"
This is the ESRI code, don't understand the error??
Regards,
Clive
ChrisAdams
Replace the brackets with curly braces:
Param{
[System.Array],
$ServerMachines
[System.String]
$ModuleSourcePath
