How to put labels under objects? (laber order)
603
02-03-2012 07:13 AM
DuccioNotari
I have the labels of a topographic layer that I want to use as a base for my map. I've set a transparency to the higher layers (so the topography can be seen but not so much), but the "topographic labels" still appear over everything.
how sould I set the correct order? I've found infos on odering label vs label but nothing on lavel vs feature!
DuccioNotari
ok, thanks!!
