How to access map service from ArcGIS server through JavaScript Application when Server is federated through Portal?
1283
06-17-2017 07:43 AM
ThomasPuthusserry
I used to generate token using the URL below (to access the map service REST end points from a stand alone ArcGIS server)
 https://myserver.com/arcgis/tokens / The JavaScript based applications uses these tokens to authenticate the map service.
Now I have installed latest ArcGIS Server Enterprise with Portal for ArcGIS where the server is federated through the portal. How can I authenticate to the server to access the map service REST end points under the current setup? What is the authentication / token URL?
Thanks Thomas
RandallWilliams
