How does ArcMap know where to draw objects?
2201
10-27-2011 12:14 PM
ChristopherMinniti
This is a decidely insignificant question but I've been curious for as long as I've used ArcGIS where the program retains the data/information for the particular geometry of objects.  And by this, I mean where is the information retained about the particulars of the polygons, such as number and relative location of verticies, length of each segment comprising a polygon, etc.
For the sake of clarity (and because I don't feel I've expressed my question well), this question comes from a discussion I was having with my co-worker.  Unfortunately, I am the resident GIS expert at my company, which is disconcerting since I'm no where near an expert with GIS.  As the "expert" I was asked by my co-worker if it is possible to fill out a table in excel with all the information necessary to create a shapefile before ever entering or using ArcMap?  I had no idea what to say...
JimW1
Occasional Contributor II
From a hack's perspective:
The geometry of features are stored in binary fields or binary file formats:
Personal geodatabase - it is stored in the [Shape] field as an 'OLE Object' which means it is some sort of binary specific to ESRI. If you Google 'ESRI Ole Object' and know some VBA you'll get a good idea of what is going on. This is by-far the easiest format to learn what Arc is doing when it stores your data.
In SDE (Sql Server) it's stored as a varbinary field that is linked to the feature class through a couple of tables. I've never bothered trying to join the correct tables to get a full view but it is basically a more complicated mdb structure to allow for versioning and such. I leave the technical stuff on SDE to the DBAs.
Shapefiles - proprietary ESRI binary format stored in the .shp portion of the shapefile - the table is in the .dbf and the .shx and .sbn are secret handshakes
File Geodatabases - a hybrid between shapefiles, personal SDE, and old school ArcInfo coverages but I'm still convinced it's just a repackaged ArcInfo coverage with SDE conventions 🙂
This is why you need VBA or Python to make any changes to the geometry of a feature class.
So it is, technically, possible to fill out vertices (say COGO) in Excel and through VBA make feature classes. I have had success with MS-Access databases where a user enters a new point in Access and the back-end changes the feature classes' geometry using VBA in Access.
I'd say 90% of GIS users will never ever touch the back-end of these data storage formats so I wouldn't worry about being the expert and not knowing. I've worked with many extremely talented GIS professionals that wouldn't have the first clue how to edit the properties of a feature through code.
GregoryElwood
New Contributor II
"...I leave the technical stuff on SDE to the DBAs."
I must be extra thick this morning...I can't figure out what "DBAs" means.
Doing Business As...???
Dead Broke Artists???
Darn Building-block Arrangers???
Of course, it'll be something completely simple, and I'll look (and feel) like a idiot.
Happy Halloween everybody!
Gregory
JimW1
Haha - those pesky Database Administrators (DBA). They get mad when lowly GIS Analysts like me try to make suggestions for SDE or SQL Server.
DarrenWiens2
MVP Honored Contributor
If you follow this paper closely, it tells you how you could literally type out a shapefile, byte by byte. Have fun! :rolleyes:
JimW1
I completely forgot about that white paper!
