How do I take advantage of single sign-on (SSO) when the Portal login is not the initial authentication?
1143
08-22-2017 11:48 AM
DavidElies
When a user uses our IDP to log into Portal, they have access to other apps which their credentials allow.  But if we log into another app that uses the ArcGIS Javascript API to access sources in Portal, they still get prompted for login credentials. Is there something simple that I'm missing that we need to do to ensure that HTTP requests to Portal are using the auth already provided?
Ranga_Tolapi
Any luck?
