Font not exporting bold
1567
03-17-2014 02:27 PM
MattBull
I have encountered a rather strange problem. I recently migrated to a new workstation with Windows 7 (formerly using XP). Ever since, I have noticed that there is one particular font that I use often with my maps that refuses to export bold to pdf. When I look at the pdf or print a map with this font set to bold in ArcMap, it always prints or exports without bold. I tried with other fonts to try to narrow down the problem, including fonts I had to move over from my old workstation, and every other font I tried exported properly. The font in question will export as underline, italic, and strikethrough, but not bold. I also tried using this font in Microsoft Word and exporting to pdf, and that worked fine, so this must be an ArcMap problem. I never had any issues like this until I switched to my new workstation with Windows 7. Any ideas what's going on?
One other thing: I even tried changing some of the map annotation to this font and bold, that didn't work either. I typically only use this font for map surround text, but I thought I'd try it anyway to see if it made a difference.
MattBull
I think I may have narrowed the problem down a bit further. I tried exporting one of the maps with the font in question as a .tif and as a .jpg, and both times it was properly exported with bold font, so my guess is it has something to do with the print settings in ArcMap.
NidhinKarthikeyan
Make sure you had checked 'Compress Vector Graphics' and increase the Resolution to 200 or 300 dpi.
TimGIS42
Hi Matt,
I'm a bit late to the party but I have the exact same problem with certain fonts loosing their "boldness" when exporting to PDF but not when exporting to TIF.
Did you find a solution for this issue?
I'm using ArcMap 10.5.1.
