Federating ArcGIS Server Error
9409
10
09-08-2015 08:41 AM
Andrew-Bowne
When I try to federate an ArcGIS Server with my portal I get the following error:
"There was a problem federating the server at this time".
I cannot seem to find any documentation on this specific error.  Any ideas?
Thanks!!
DanFranklin
When I go to federate the ArcGIS Server I get the following error message:
"Unable to federate at this time"
When I look into both the Portal and AGS logs I get the same error message:
"Failed to update the security configuration. Cannot update the security configuration as server is not registered with Portal".
When I set the AGS logs to DEBUG I get this message:
" Testing to see if this server has been registered with Portal as a federated server. Failed to test if the server is registered with Portal"
Then it states: "File or directory not found" in relation to http://www.w3.org/1999/xhtml and this of course cannot be accessed as it is a completely disconnected environment.
I have also checked the following at 10.3.1:
  • I was able to add store credentials of a secured ArcGIS Server service from the AGS I am trying to federate against so that proves that the certificates work as expected.
  • ROOTs and INTERMEDIATEs have been imported into the Portal Java keystore.
The main confusion stems from the fact it was federated earlier this morning, the URLs I used were similar to these (with the actual names removed for security reasons)
SERVICES URL: https://machinename.domain/arcgis
ADMIN URL: https://machinename.domain:6443/arcgis
The correct PSA details were used in the username and password.
Does anyone have any further input on what the "Unable to federate at this time" corresponds too?
