My team and I have run into an issue where all the features of a service won't draw when using the full rest service of a map service.
When I say full rest service I mean something like this: .../services/AdministrativeAreas/Home_Owners_Association/MapServer/0 (<-with the number at the end)
When using the top tier rest service (.../services/AdministrativeAreas/Home_Owners_Association/MapServer) things draw perfectly fine but you get that weird grouping in the Table of Contents that is highly annoying.
To avoid that issue we use the full rest service (with the number at the end) because it doesn't do that. But we have run into the issue of features not drawing.
And this isn't just one service. It is almost all of them that we can see and not all of them have a ton of features. Like the homeowners associations for example only has 83 features and yet it still won't draw all of them with the full rest service.
This is only happening with the map service. Both the top tier and full rest service of feature services work fine. This is also only a Portal issue. We have not seen this issue in ArcGIS Online.
Has anyone else seen this issue and know what is happening?
We are using ArcGIS Enterprise 10.7.1
