Export map Navigation
991
06-17-2012 05:19 AM
YaronCohen
Hi there,
I working with arcview 9.3. when i export a map , the arcview exported it,by a default, to the previous file that has been exported to it a map.
the problem-  when I work on a diffrent mxd file that located on a diffrent file , it will be exported tolast file that has been exported to it a map
Is there a way to change the Definitions of the arcview that when I export a map it will be exported to the file that I actually working on without navigate by me to the Desirable  file  ???
I would appreciate if someone could provide a solution for this default!
Thank you very much in advance!
Kolsason777
