Error: The item was not found While creating offline areas (11.5)
1574
6
07-29-2025 01:45 PM
vijaybadugu
I am getting an issue while packaging offline areas through ArcGIS Portal "Error: The item was not found. The item was not found. The item was not found." I checked the item, it is there and was able to open without any issue
CodyPatterson
MVP Regular Contributor
Hey @vijaybadugu
Are there any issues within your Portal or Server manager logs?
Cody
vijaybadugu
"code": 6, "messageCode": "OffPkg_ 6", "message": "Failed to get item <id> error Error code: 400\nDescription: Bad syntax in request.\nMessage: Item does not exist or is inaccessible.\n", "params": {"itemId": "<Id>", "error": "Error code: 400\nDescription: Bad syntax in request.\nMessage: Item does not exist or is inaccessible.\n"}}
CodyPatterson
Hey @vijaybadugu
Hmm that is strange, is this a published feature service? If so, would you be able to restart the feature service through the Server Manager? I'd also try manipulating or writing information to the layer while within Map Viewer on the Portal itself. Along with that, if there are any offline areas in the Map Settings that you can see, you may try revoking those and seeing if it comes back maybe.
Cody
ChrisUnderwood
Hello @vijaybadugu , I think this may be a package size issue.  According to the Portal for ArcGIS 11.5 documentation, the limit is 4GB. Is it possible you are exceeding this (remember attachments etc also count towards that limit) ?
https://enterprise.arcgis.com/en/portal/latest/use/take-maps-offline.htm#:~:text=Packaging%20for%20a...
vijaybadugu
All individual offline maps are around 1GB size. it was working fine before.
PalomaGómezGonzález__8
Hello,
did you find a solution? We have a similar problem.
